Trying to determine Overall Drive Ratio
Alumarine
Hi there, I need some help determining the final drive ratio on my 3.0.
It has what I believe is a #1 upper and a MR/Alpha lower.
I took the top cover off.
The upper gear set is definitely a 20/24 as I can read the number 43-55766 on it (and I counted).
I marked the top of the drive shaft into quarters and (approx) 1.62 turns of it rotates the prop 1 revolution.
Thanks for any help.
alldodge
I would mark the shafts, put it in gear, then rotate the drive shaft 10 revolutions. After 10 revs it will be real easy to determine
Ayuh,...... The over all gear ratio is changed in the upper unit,.....
Up until the Gen.IIs, ALL of the lower units were 1.65:1,......
Alumarine
When you say driveshaft do you mean rotate the motor 10 times?
alldodge
I have to write that down some place I can find it later, :thumb:
Alumarine
Ok, I checked parts diagrams for a few different drives prior to Gen II and they all seem to use 17/28 gears as standard.
Bt Doctur
[h=2]Mercruiser R-Style Sterndrives (1969 - 1983)[/h]
2.5 Liter1202.5/15341.9820-241969-1983
2.5 Liter1302.5/15341.9820-241969-1983
1651653.7/22461.6524-241969-1983
470170 - 1904.3/26241.8417-191969-1983
215 - 233205 - 23035181.520-221969-1983
2602605.7/35081.520-221969-1983
Engine HP Liters/CID Cylinders Gear Ratio Tooth Count Year
[h=2]Mercruiser Alpha 1 (1984 - 1990 Models)[/h]
2.5 Liter1202.5/15341.9820-241984-1990
3 Liter1303.0/18141.9820-241984-1990
1651653.7/22441.8417-191984-1990
1751754.3/26261.8417-191984-1990
180, 190, 4701803.7/22441.8417-191984-1990
2002005.0/30581.6524-241984-1990
2052054.3/26261.8417-191984-1990
2302305.0/30581.520-221984-1990
2602605.7/35081.520-221984-1990
350 Magnum2705.7/35081.520-221984-1990
[h=2]Mercruiser Alpha 1 Gen 2 (1991 & Newer)[/h]
3 Liter1303.0/18142.024-241998-2005
3 Liter1303.0/18141.9420-241991-2005
4.3 Liter1754.3/26261.8117-191991-2005
5.0 Liter2305.0/30581.6124-241991-200
Bt Doctur
[h=2]Mercruiser R-Style Sterndrives (1969 – 1983)[/h]
470170 – 1904.3/26241.8417-191969-1983
215 – 233205 – 23035181.520-221969-1983
[h=2]Mercruiser Alpha 1 (1984 – 1990 Models)[/h]
5.0 Liter2305.0/30581.6124-241991-2005
5.7 Liter2605.7/35081.4720-221991-2005
  • Email*
  • Name* First Last
  • Phone*
  • How can we help?
achris
More fish than mountain goat
Easiest way to determine drive ratio, without stripping the drive and counting teeth, is to remove the spark plugs, have a helper (or wife/offspring) count the turns of the prop as you turn the engine. Obviously with it in forward gear... Count engine turns as you go, and when prop shaft turns reaches 10, divide the number of engine turns by 10 and you have the ratio...
Alternately, use DonS wonderful drive ratio tables in the stickies and just look it up... And yes, as the drives before the Gen II (What stupid name shall we give those? "Alpha style"?) most had 1.65:1 (the last ones had 1.62:1, but the difference is ignorable), we can assume that with a 20/24 tooth count in the top box, the overall ratio is 1.98:1 (or 1.94:1 for the later ones)... And that is the factory standard supply with a 3 litre engine. :D
Chris.......
Alumarine
Thanks guys. Once I track down a helper I'll rotate the motor and determine how many rev's of it for 10 turns of the prop.
It will probably take a week or 2 before that happens.
