trying to confirm model year
Epsagent
I have a 25hp Mercury outboard - 2 stroke, two cylinder
serial# 945 0208
i have tried to use the sites listed above to identify the year of the motor, but have not been able to get two answers that are the same.
Name Plate reads:
Serial # 945 0208
Marine Power Europe Inc.
made in Belgium
Any ideas,
thanks
Epsagent
Re: trying to confirm model year
bump....
I will try to take some pics, maybe that might help
Epsagent
Rscardina
if you pull the cover off and check around the block you should find a quarter sized plug or frost plug that has the model and serial stamped on it...
Epsagent
will this plug s/n match the plate s/n
thanks again for your help!
Rscardina
it should...unless some work was done that changed that..meaning if a new powerhead was installed...
Any idea what year the engine is? even a guess?? I saw a website that has mercury outboard number cross refferences but all show the 25 horse a a model 250.. i could not locate the serial number range you had..but then again it was broken out by year..
Epsagent
on one of the websites listed above I narrrowed it down to 1986 - but no other site can confirm this
Rscardina
based on the numbers if your serial number is between number changes..example 6593849 is the start range of 1985 year and the next set is a911346 is start of 1986
then your engine falls in the 1985 year.
Rscardina
well...boat tech to the rescue!!
How the heck did you find all of that??. Eveything I could find showed it as a 85...
Good show..
Fun Times
Good show..
It's an ancient chinese secret. :p:D
Epsagent
Thanks to Boat Tech! ;)
and to RSCARDINA - you were a big help!
I need to order parts for this, and wanted to make sure I get the right stuff.
Thanks again
:cool:
