old wise bison
Thread starter- Joined
- Aug 6, 2009
- 29
I.m trying again to find out how to unhook the shift rod from the (u shaped clevis shaped holding device) I removed the small bolt and pulled the horizontal shaft. the remaining clevis clamp is still engauged to the shifter rod. Is there a spring loaded part to the pin or why wont the clamp disingauge from the shift rod. Thank you
