Expidia
- Aug 26, 2006
- 2,368
Since I got my rig in 2007 I always wanted to weigh it on a truck scale, but never got around to it. My Shoreland'r instruction sheet said 5-7% tongue weight. So I added up the weight label on the trailer, outboard and boat plus equipment gas, battery etc.
Past year I put a hitch on my Wife's 2000 Saab 9-5 6 cyl to take the pressure off the past 6 years of towing with my 2001 Saab 9-5 4 cyl. with 170k on it.
But noticed even though they were the same models and I would switch same the hitch ball attached to the receiver between the two Saabs I noticed her car always had more of an annoying tugging back and forth especially when off the highway roads.
So I said to myself . . . I'm finally going to find a truck scale as I'm sure there is not enough tongue weight. So last week on my way home from a lake I spotted a sign that said "certified truck scales" at a truck stop on I-87 just north of saratoga springs, NY. I pulled onto the scales and unhooked my tow vechicle drove off the scales leaving the rig there alone. You press an intercom button and the cleark says all set and to drive around to the office and pick up the print out. It costs only $10 and took about 5 minutes of my time.
For the past 6 years I had estimated everything to weigh around 1100 lbs and that's what I've been using for the 5-7% tongue weight when I put a bathroom scale with a board across it under the tongue.
To my surprise, the prinout said 1,653 lbs Man, was I "weigh"off . . (git it? weigh off) . . only by about 33%. So I'm posting this to suggest if you are looking to set the proper tongue weight for towing, don't wait 6 years like I did. Just pull into a truck stop that has scales rather than guestimate
