SkaterRace
Master Chief Petty Officer
Thread starter- Joined
- Mar 20, 2016
- 842
I have a 2023 Chevy Silverado 1500 without the max towing package. It is not ideal but works fine for my 21ft center console boat. However, it sits a bit low for my comfort which I suspect is tied to what it was reporting last time I drove it. It says I am over hitch weight (GVWR) however I should be able to tow 9000 lbs and no way in hell does a 21ft center console weigh over 9000 lbs even fully loaded on an aluminum trailer.
The boat feels very comfortable behind the truck, gets up and going fast enough and brakes very well. Not as good as my old Ram Rebel but 9k vs 12k is a big difference in towing
Weight breakdown
2019 Blackfin 212CC without an engine -3600lbs
2019 Mercurty 225XL - 475lbs
2019 Load Rite aluminum tandem axle trailer - 6340-5200 = 1140lbs
Full fuel - 646lbs
Gear onboard - 100lbs
A total of 5961lbs which is 3039lbs under the weight limit and at a 10% tongue weight should give me ~600 lbs of tongue weight well under my stated max of 900lbs (door jam says this for conventional towing)
Any ideas what might be up with it? I am guessing adjusted wrong but it sits so well I am not sure what to do about it. I also have no clue how to adjust it myself and would never feel comfortable doing it myself.
Weight breakdown
Full fuel - 646lbs
