Ok Guys, Need your Help.
I have a 98 dodge dakota with 135k miles. The A/C works like this. The lower the blower motor speed the colder it blows (About 42 degrees on low). When I turn it to high, it blows about 20-25 degrees hotter. I checked the pressures and the high pressure is about 225-250 lbs and the suction is about 62 lbs. It's my understanding that the suction should be about 35 to 40lbs.What's causing a "high" suction pressure? :devil:
