hkeiner
Thread starter- Joined
- Oct 17, 2006
- 1,055
I generally understand that a speedometer gauge works by measuring the air pressure in a tube coming from the pickup located in the lower unit of my motor. I also understand that the pickup and tube have to be clear and unplugged for the gauge to work. I also understand that the water pressure at the pickup causes the air in the tube to compress which the gauge at the dash then measures.
I don't understand, however, how far the water normally moves though the tube (from the pickup towards the gauge) when everything is properly connected and whether it would flow through the tube if I were to disconnect the tube at the gauge and then drive the boat. I would like to know this for troubleshooting purposes. I figure that by monitoring the water flow rate in the hose before and after I poke, prod, clean, or replace the pickup and hose, I can tell if it is doing any good.
The speedometer on my boat does not work most of the time. It does randomly show the accurate speed for a few minutes at a time, but mostly it justs displays 0 MPH. I was thinking of disconnecting the tube from the back of the gauge and then monitoring the flow of water coming through the tube while the boat is moving at varying speeds. I presume that if the hose is disconnected, then the air could escape and thus allow the water to flow through the hose. This would not work, however, if there is some type of membrane in the pickup preventing the water from flowing into the hose.
Thanks for any infomation on this.
