Trottle lenkage frozen
flabob1
Found shift rod frozen. Lubed and got it moved a little. Removed lower gears and prop. thought the rod would fall out after loosening the control. Cannot rase the control or lift off the throttle leakage How do you replace the control bracket. 2018 Yamaha LF150 XB engine
