trolling motor
waterman556
I have searched the forum for a post that told about a quick release and very low profile mount for a trolling motor .I have looked at the motor guide and minn kota and their pontoon mounts are not really a quick release or low profile for what I am looking for ,The one I saw was only and couple of inches tall and had a snap release. Thanks for any infomation you have. Randy
Re: trolling motor
I have a quick release plate from MinnKota on my pontoon. It is the very inexpensive (two aluminum plates that slide together) variety as shown here. It works great and nearly indestructable.
http://www.iboats.com/Minn_Kota_Pow...31405391--**********.700279688--view_id.38868
If you are trying to use a transom mount motor on the bow of a pontoon, then your only choice is a pontoon mount that is relatively tall, or else some sort of home made setup.
flycaster
Re: trolling motor
MKA-21 Quick Release Bracket
Composite
Easily remove your bow-mount motor with these high-yield composite brackets. They?re ultra-strong, corrosion-resistant and feature a low-profile design that leaves the deck clear when the motor is removed. A locking handle with stainless steel pins can be secured with a padlock (not included).
Composite Quick Release Bracket Details
Compatible with any Terrova, PowerDrive V2, PowerDrive or Pontoon Hand Control models.
This is the mount that I used to mount my Min Kota on the front of my pontoon.
can be viewed at minkotamotors dot com.
tashasdaddy
Re: trolling motor
i am using a motor guide WP45 wireless, just loosen a twist knob, and lift off, it also has a very nice cover plate. i have one mount on both boats, so i can swap the motor from one boat to the other.
J JACKSON
Re: trolling motor
i am using the same one flycaster is the mka-21 for a minn kota it works well and only leaves a small block 3x4x 1 high on the deck
Pontuned
Re: trolling motor
That is the one I use as well. It works well, the only downfall is that it casts about 100 bucks.
