Trolling motor won't work
riflleman1
I have a 12V bowmount motorguide. I took the boat out first time this year and the trolling motor just stopped working. I have done troubleshooting at it works fine if i hook it directly to a 12 volt source. I have checked the battery and I am getting 12volts at the plug but it will not work when I plug it in.
j_martin
Re: Trolling motor won't work
Dirty connections.
It only takes about .001 amp to run a meter, but many amps to run a trolling motor. Meter won't see a voltage drop through 10 ohms, but a trolling motor won't see any power through the same 10 ohms.
