Re: trolling motor wiring
Generally Yes -- but you did not provide all the information regarding your 12/24 system. Is there a 12/24/Run/Charge switch on a panel up front? How many wires do you have running from the batteries to the bow? The answer will be three or four. Since a 12/24 motor runs on 24 volts there is no reason a straight 24 volt motor won't. Just make sure you identify the 24 volt terminals in the receptacle and match them to the two terminals in the 24 volt motor plug. I the current system wiring has not been messed with, you can leave everything the way it is, set the 12/24 switch (if you have one) to 24 and leave it there.
