I just bought a little 10' Scooter Pirogue which I know nothing about. I saw a post that may date it back to the 80's. This boat has a short shaft trolling motor mounted underneath the rear of the boat and has stick steering on the side of the boat where you sit. The wiring is loose coming from the motor which has 4 wires (Black, Red, White & Green) There was a control panel which looks to be two 3-way switches. One being a "Forward", "Off", & "Rev". The other being another 3-way switch with "Low", "Med", & "High". My question is where could I find a wiring diagram for this type of setup. I fairly sure it's a 12 volt setup, but I can't figure out what I need to replace and wire the panel. Any help appreciated.
