Trolling motor deep cycle batteries parallel question
Starkonian
I run an inflatable powered by a trolling motor. I purchased a Walmart EverStart Marine Battery, Group Size 29DC last summer and it has approximately 15 trips/cycles on it. It charges full to 13 volts. I just bought anther one only it's the MAX model. It's supposed to have 30% more cycling capacity and weighs about 4 lbs more than the standard model. I've read the less batteries drain down, the longer they last. Can I connect these two batteries together in parallel given the battery I've had for a while is still relatively new? Or, would it be better to run them separately?
211libwtfo
It’s done in big boats all the time except they use a perko switch and I don’t think you’ll want to run 24v to the trolling motor but it’ll make it run faster and will lower the life expectancies of said motor
Starkonian
Running batteries in parallel does not double voltage. Just the capacity. Running them in series doubles the voltage, or increases it anyways.
GA_Boater
Connecting two or three or four or more batteries in parallel yields 12 volts, not 24.
Stark - Since your batteries are mismatched, I would use a battery switch to run, then the other. That's just me because the older one will discharge faster because of lesser capacity.
A little bit of info - https://www.batterystuff.com/kb/articles/battery-articles/battery-bank-tutorial.html
GA_Boater
right but in series it will
You are the only one talking series.
Even Stark in his opening posts said he was doing a parallel setup, so he knew what he was doing;
I just saw that my link was censored for some reason - it was https://www.battery stuff.com/kb/articles/battery-articles/battery-bank-tutorial.html Take out the space between battery and stuff.
