I purchased a used 2006 Glastron a couple years ago, factory wired for 12/24V trolling motor. It?s always been operating on 12V since I bought boat. I finally got tired of that and had a mechanic show me how to operate on 24V. Only problem is the 40 A Short Stop circuit breaker on battery #2 now trips after running 15-20 seconds when TM is in water on 24V.
Each of the two batteries is connected directly to a small device on control panel at bow of boat. On back side of this device are 4 terminals, A+ and B+ and A- and B-. Positive (red and orange) wires from each battery go directly to the terminals marked positive on the little device and negative (black) wires from each battery go directly to the neg. terminals of device. There appears to be no wire directly connecting the two trolling motor batteries.
Front side of the little device has receptacle where plug to TM plugs in. 12V or 24V operation is selected by moving the red wire of TM plug to 12V or 24V leg of plug. There is also a small white button on control panel with no identification as to it purpose.
I took TM in thinking there was perhaps an issue with motor but mechanic said there?s nothing wrong with it. I suspect there?s a reason TM was set up on 12V when I purchased boat. Last, I?ve also tried taking the on-board charger out of the equation and that doesn?t seem to have any effect on the situation. Any suggestions or thoughts as to problem?
