redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,471
Curious, what voltage is your trolling motor?
OK, thanks didn't have instruction to be found.Your positive wire from the battery should go to the stud on breaker marked BAT. Your positive wire from the motor goes to the stud marked AUX. Your negative cable should go right from motor to battery, not through the breaker.
Your breaker is wired backwards. The line (power source) should connect to the terminal marked "line." The load (trolling motor) goes to the terminal marked "load." Swap the wires.Hooking up trolling motor finally and the breaker i have, couple years old but never used, seems to work in reverse. When in protect mode no power. When I hit the test/trip button the lever pops down to be reset but then I have power?
