Trolling motor change
Rtbbama
I have 24V trolling motor, it appears to have died. I want to replace it with new 12V. I have the switch at the front that is 12V charge 24v run. How do I make the change? Or is there anything I need to do?
Silvertip
Honorary Supreme Mariner
Re: Trolling motor change
Leave the switch in 12V charge. Now use a voltmeter to probe the trolling motor plug to find 12 volts and ground. Wire the troller plug accordingly. NEVER switch the Charge/RUN switch to 24V RUN with the trolling motor connected.
