Re: Trolling Motor Battery help?
Ok, while askign for "yellow" might get you buy, it's not a full answer.
How much battery you need depends on: a) the size of your motor b) What speed you run it at (on average) c) how often you run it.
i.e. A 30# motor that is run on/off @ 1/2 speed to menuver a jon boat is going to need near 1/2 the battery reserve as a 55# motor run the same way. Run either for extended periods (as primary motor) or at higher speeds ( due to current , wind or inadaquate motor size, and the need for juice goes up ALLOT. (and usually at the most inopertune time.)
Having said all that, you want a DEEP CYCLE battery. ( I also like the Wallmart brand for value and performance). These batteries come in two comon sizes. Series 24 (about 9" long and 50lb) and series 27 ( about 12" long and 70lb.) They also carry amp hour ratings that basicly tell you how much reserve power they can hold . ( Not all of the same size are equal.) If your motor is small and/or you are only using it to menuver on a smaller boat, a good series 24 battery will last you 7-9 hrs of fishing and save you a few pounds of carry weight. IF you want reserve power for windy days /current or just speedy returns to the ramp, (or plan to use it as your primary drive), definatly go with the bigger series 27 ( or consider two series 24's). In either case, get the Best Wallmart sells as they have the higher reserve cranking amp ratings.
FWIW, While a good battery may cost $70+, it should last years and costs pennies to recharge. Buy a good one of adaquate size up front and avoid years of grief.
