have a 37 lb thrust motor guide trolling motor ,and when trolling on high speed the circuit breaker will pop after a few minutes of continous trolling. I have a 20 amp breaker. Does anyone know what the amp draw is on this motor.
About 37 amps at motor stall speed. If the wiring is sufficient, I would use a 40 amp breaker. The breaker is to protect the wiring from shorting out and causing a fire, more than to protect the trolling motor from damage.
Interesting this would come up today. I was looking at a wind blown tag on my minn kota last night and it said to install a "manual reset breaker". I know I installed a auto re-setting one. I guess this is so the motor is under observation if/when the re-setting occurs? Kind of makes sense when you think about it. Best of luck. Rick.
