Re: Troll Motor / Bow Mount on Center Console w/ Bow rail
Here's a possible idea. Just got done checking some measurements on my Minn Kota powerdrive PD-55.
It's hard to tell by your photos how much clearance there is between the rail and the gunwale at the bow. If you have 14" between the surface where the trolling motor would be mounted and the bottom of the rail, it would be possible to mount the trolling motor directly to the gunwale - under the bow rail (presuming you choose a motor with the same dimensions as my PD-55).
To make this work, you'd have to make sure you fully deployed the motor shaft as far as it can go, before allowing the motor to pivot to the vertical. Once the motor pivots to vertical, you could then adjust the shaft for proper performance of the troller. Stowing the motor would be the reverse.
This is not an ideal answer, as stowing and deploying might require some gymnastics, but it might be your best alternative.
Gary
