Boatin Bob
- Sep 24, 2001
- 1,858
Re: Tripping GFI for shore power
Chris...I would remove the shorepower connector on the outside of the boat, if it's a good quality one it should have come with a gasket between it and the boat, when removed check the wiring for correct connection, loose or even chaffed wires, even though it's only a few feet of wire to replace I like to know why I'm changing something before I do, it could even be wired wrong inside that breaker box you found, just because you tripped the breakers who knows if they are wired correctly?
