Trim Troubles
mentor70769
When I am running at 20 mph and above and my motor is trimmed up, it starts dropping slowly. I have checked for leaks and there are none. When the motor is trimmed up I have put downward pressure on it to see if it would hold and it does. Only other thing I can think of doing is checking and cleaning my electrical connectors.
Any ideas please suggest them
foodfisher
Re: Trim Troubles
Probably an internal valve body leak. Hang a concrete block on your up tilted motor, it'll come down. The forces exerted while running are far greater than you pushing on it.
mentor70769
Re: Trim Troubles
Thanks, thats worth trying
