Trim & tilt
jcm900
I have a 1976 thunderbolt 850 85h outboard motor. I am looking for a tilt & trim system. can any body tell me if this one will work? The Mercury Original Part Number for the Trim Unit is ME-PT-01-R. The main unit has "7 H 31 A 39" stamped on it. There are also earmarks on the back "0 3 TK 29 7"
The motor has a small plate with "13217" stamped on it.
The two Mounting Arms have 3401-8717-01 & 3400-8715 stamped on them respectively.
Chris1956
Re: Trim & tilt
The PTT unit that fits that motor has the trim pump and resevoir that mounts in the boat, and the two cylinders that bolt to the outside of each side of the transom clamp. You will need th brackets that hold the top of the cylinders as well.
Crowleymarine.com has a parts manual that has some #s and pictures, for that motor. You might look it up.
