Re: Trim/tilt setting on outboard
hahaha, point well taken there. <br /><br />Ok, so what I am reading here, I need to find out why the motor is not going hard up against that pin. Right?<br /><br />I took a look at it just now, when I trim the motor all the way down, I can't see into the motor mount to see the 3 hydralic rams. From the last point that I can see them though, it looks like they are bottoming out in their cylinders. When the motor stops moving there is a change in the pitch of the electric motor driving the hydralics likes it can't go anymore. So I would think that it is bottomed out or there is something obstructing the movement. The plate that the rams connect to that moves up and down covers all the hardware when trimmed all the way down. When I lift the motor up there is a rubber snubber that is on the ram assembly but there is no indication on the motor side that it is making contact with anything. What I mean is if it were making contact with the motor side there would be a "clean" spot where the snubber makes contact. I don't see anywhere that I can adjust anything on the rams or the engine.<br /><br />What next?<br /><br />Oh yea, regarding the rolling start, that is what I have ended up doing. When it blows out, i back the throttle off until it catches then ease back into it, once it's on plane I can throttle up and start trimming it.<br /><br />When I just easy into it, I can get on plane without blowing out. My last question, as long as I ease into it and don't over rev the engine, is this just a nusance? Or can I do any kind of damage? Other than risking over revving the engine?
