Trim Tilt Problem
Alex458
Hi, I have a 1985 Evinrude 65 on my boat and ever since I got it the trim tilt hasn’t worked properly. To make the motor go upward each trim ram will extended one at a time before the engine will lift, when you go to drop then engine down again the trim rams will suck in one at a time before the main lift cylinder will move. Unit is not leaking and does not fall back down over time once it’s lifted up. I know that the hydraulics will move whichever ram has the least resistance first. Anyone had this problem before and can give an answer on what to look into? Haven’t found anything on the internet or with local people that can give me a good answer as to what is wrong. Thanks
