trim/tilt motor help
mysweetone
The motor for my pump died last weekend in the middle of the lake. The selonoid clicks when trim and trailer buttons are depressed but nothing happens. Got the drive up by rapping on the motor casing with a small ratchet. Motor sounded horendous but drive raised up smoothly. This is why I believe my problem lies with the motor itself and is not elecrrically or pump related. Can anyone tell me what motor I need to replace this? The plastic casing reads SAE 1171J. The outdrive is a Bravo II if that helps any.... Any help would be appreciated.
Bt Doctur
Re: trim/tilt motor help
more likely its sticking brushes, should you decide to replace,pm me about the old one
