Trim Tilt Gauge Suzuki 65 HP doesn't work anymore
Cor
Hello,
Once in a sudden mij trim tilt meter on the 65 DT Suzuki stopped working. It stays in the max. up position. When I switch of the contact, the gauge is going down to it's start position. Trim tilt just works fine, only the gauge doesn't follow the position of the motor. I checked cable connections on motor and trim motor, nothing special, and no corrosion( Fresh water use only)
Anybody an idea where to look for?
Thanks so far,
