Trim/Tilt from scratch
Frank Acampora
Hey Rritt: I am putting together this trim/tilt from scratch
with nothing to compare it against. Which two ports are the up and which two are down? Thanks in advance.
RRitt
Re: Trim/Tilt from scratch
i don't know. just run it over a bucket and see which holes squirt out fluid when you touch the blue wire to positive.
Frank Acampora
Turns out that AFTER I assembled the system, I realized that my Force 150 has the same one. The two center ports are UP and the two outside ports are down
