Trim Tab Anode
nodding2003
What happens if the Trim Tab Anode breaks or comes off while you are moving. 25Hp Tiller Mine Is cracked and I need to know what will happen. Thanks
Charlie61
Re: Trim Tab Anode
it control the water flow and help run the boat drive stright also help control power from the prop. it would be helpful to see a picture of it
nodding2003
Re: Trim Tab Anode
Thanks, I guess what I am asking is will the tiller handle fly out of my hand and the boat start veering to one side or the other if it breaks off while I am moving?
Charlie61
Re: Trim Tab Anode
yes it would likly go one way or the other , all about how must it break .i may be able to buy a used replacement for 200 or 300 luck be with you
Texasmark
Re: Trim Tab Anode
I seriously doubt it. I don't know what hp you are running, but lots of smaller engines don't even have one. I have run many engines without them. Really the only need for it is when you get OB's so large that the offset caused by prop torque puts more pressure on the steering than you want, or feel like controlling.....like having a car with the front end out of alignment. Every time you turn loose of the steering it wants to wander over to the side of the road.
Mark
Re: Trim Tab Anode
Mark is correct. On your small motor, you may (may) notice that the motor pulls a bit more to the right. Why not replace it before it breaks?
Blown Challenger
Re: Trim Tab Anode
Sorry for the hyjack but if the boat pulls right,witch way should the trim tab be facing?
nodding2003
Re: Trim Tab Anode
Thanks, I have ordered a new one. Just wondering if I could go out on the lake with the cracked one while I am waiting on the new one.
Re: Trim Tab Anode
I would not worry about the anode breaking......I doub't it will do any damage.
