Trim Tab Adjustment
dblanton
On a 1981 75 hp Evinrude at full throttle the steering wants to constantly pull to the left. Which way should I adjust the trim tab (left or right) to correct this? I am assuming to the right but I want to make sure, and I am assuming that a slight adjustment would make a bid difference.
Laddies
Banned
Re: Trim Tab Adjustment
You move the tab in the diriction of steering whell torque, in your case left
wilde1j
Adjust to port (left facing forward. Small adjustments, yes.
dblanton
Thanks I will make a small adjustment and give it a try.
