- Jul 18, 2011
- 18,927
As I'm getting the boat ready for splash day in about 2 weeks, I have noticed that the Port Outdrive does not want to stay up . . . slowly lowering itself over the course of a day or 2 :facepalm:
I did some measuring over time yesterday, and it looks like the trim cylinders collaspe at about 1/8" every 1-2 hours.
This seemed to have come on recently, as I did not notice it earlier this spring. So, I did some obvious things, like check everywhere for leaks . . . no leaks found. Checked the fluid level . . . A-OK, no issues with the fluid. I ran it full up and down a few times, just to see if there was any air to purge. All of those things did not seem to make any difference.
So, I'm thinking that it might be some blow-by in the trim cylinder(s) or some backflow at the pump :noidea: I did some searching, here and on the web in general, and it looks like I should try to isolate the issue to either the trim cylinders or the pump.
So, I just want to check my approach and get any advise/comments:
1) I was planning raising and supporting the outdrive, then disconnecting the hydraulic lines from the pump and joining them together with a flare nut coupler, 'release' the outdrive from its support, and give it 6-8 hours to see if the outdrive lowers itself (this would mean trim cylinder issues)
2) If the outdrive were not to move during the 6-8 hours of testing, then I could assume it's a pump issue.
Does this approach seem about right? Anything else that I should do ?
My preference would be to have to fix the pump rather than the trim cylinders. . . but with my luck . . .
Engine and outdrive info is in my sig below . . . TIA.
