:welcome: aboard Mshady76. nice to have you join us...
Obviously there is a wiring problem and not the switch as being bad. If you own a meter and know how to use it, start ohming out the wires to see where the break is at. There should be connections from the trim switch at the front to the trim at the engine. It is more likely a corroded terminal connection... JMHO!
