trim switch not working on mercruiser
Samckay
trim switch on throttle stopped last fall suddenly. trim Still works fine from trailer switch on back. Am planning to replace throttle switch. Looked online but have not been able to find. Help please...
I have a mercruiser 5.0 alpha gen 2 from 2002.
thanks in advance
raven1978
Re: trim switch not working on mercruiser
You need to know what handle you have to get the roght style of switch, motor and drive wont give you anything. I think there are about a dozen different styles of shifters/throttles. Quick search found these.
Mercruiser Trim Switch: Boat Parts | eBay
UncleWillie
The throttle mounted switch is actually three switches in one. Two UPs and one DOWN.
Other than obvious physical damage, the odds of all three switches going bad at once is slim.
I would confirm the problem is actually the switch before you go throwing money at the wrong problem.
The symptoms would suggest it is more likely that a wiring harness connector has come unplugged.
wrench 3
Did it quit working in doth directions or just for "out"?
Ayuh,... Welcome Aboard,.... Ya oughta be testin' the circuits, Before ya go rippin' things apart,...
A meter, or test light makes life alot simpler,...
stonyloam
There is about a 90% chance that it is NOT your throttle switch, so leave it alone (for now). Chances it is the trim limit switch on the outdrive. Try this: go to the stern and locate the two black wires coming through the transom. One goes into a connector with a purple/white wire and the other into a connector with two blue/white wires. Unplug the black wires and use a piece of wire to jumper between the two connectors. Try the trim switch. If it works the problem is your trim limit circuit.
thumpar
Yep. I would bet on limit switch first. Get a meter and start testing before replacing anything.
UncleWillie
If the Trim UP Button (1[SUP]st[/SUP]Click) does not work, but the Trailer UP Button (2[SUP]nd[/SUP]Click) works,
that would indicate a problem with the Limit Switch.
wrench 3
Also the down/in switch will still work if it's the limit switch that is the problem.
