Hi, I have a 1984 Checkmate with the Quicksilver Throttle/Shift Controller. While out for the day, we came in and couldn't trim up. Looked and the 20amp inline fuse was blown. We managed to hotwire to the motor to raise it. Got home and replaced the fuse, and we can use the trim switch to lower the drive, but not raise(does nothing). I can use the trailer button to raise the drive. Need some advice as to whether it is something in the trim switch itself or should I look somewhere else. Also When I took the shifter handle apart to look to see that the connections are good, a small ball bearing fell out. Can't see anywhere in the handle it could possibly go! It was just rattling around in there. Thanks, Dan
