Trim switch intermintent
Evinrudetrue
My tilt trim switch works then doesn't it will work fine one time and raise and lower the motor then next time I hit the switch to raise or lower it won't. I'm thinking its a wiring issue or its in my switch itself but would like someone else's advise or expertise on this. My motor is a 150 evinrude V6 my problem lies in the remote control box and that's where my tilt trim switch is located at the model number of my motor is E150ANCRS
LaborOfLove
It might seem like a stupid answer, but have you made sure the connection to the battery is secure? I had the same problem and it turned out to be that the contact just wasn't tight enough on the terminal.
emdsapmgr
It is possible that your tilt switch in the control box is faulty. You should be able to do a simple continuity test on the leads at the switch connector about 2' down the wire harness from the control box. Unplug the switch at that connector and use a simple voltage tester to check for switch continuity in both the up and down positions. If it tests bad, the switch is NLA. Part number 582078 supercedes to 395821. Both are NLA. Some Bombardier dealers in the U.S. still have one of these new parts in stock. If it tests ok, then have a look at the two relays inside the trim control box. It's the box that bolts to the back of the powerhead exhaust cover inside the cowling. Two of them. One controls the up movement, the other controls the down. They are identical and can be swapped for testing purposes. These do fail over time. If one is bad, best to replace both of them at the same time and keep the old (good one) as a spare in the boat.
I have a similar issue. The trim switch in the throttle handle doesn't always work in the down position. Taking it apart revealed that the piece of stainless steel that holds it in place was out of place. The button was recessed into the handle more than it should be. Resetting that "keeper" helped it to work better.
emdsapmgr
I've also experienced that switch recessed problem-making it difficult to move to the down position.
