Trim Sensor & Relay?
Streamfixer
2003 F115 Yamaha
I have checked the resistance of the sender wiring (pink to black) with the motor down (in shop) and get a reading of 107 ohm.
I went to raise the motor to check variance in the resistance only to have nothing happen at the pump, no noise, nothing.
I suspect the relay has given up.
This brings me to two questions:
Where is the tilt/trim relay physically located so I can check it as set out in the Yamaha shop manual
Where is the trim sender physically located so I can perform the check (or R/R) on that system too?
Thank you
rodbolt
Re: Trim Sensor & Relay?
trim sender has absolutly nothing to do with can the trim opererate.
the trim relay is located on the front stbd side of the engine under the electrical panal cover.
boatguy823
facing the front of the engine the tnt relay is located underneath a black plastic cover remove this cover by depressing the three tabs and the relay is towards the lower left.
the sending unit is located on the swivel bracket behind the tilt tube
