Trim sensor help
joelger
I just bought a 2011 searay 250SLX with the mercruiser 8.2 and bravo 3 outdrive. The sterndrive serial is 1a446515.
Im in trouble already. The trim gauge was not working so i thought how hard can it be to replace the sensor?
I found out fast enough that the drive has to be removed. Somebody blew it in this design. I can access the bolt to remove the wires that go through the transom plate without removing the drive but as i turned it about 1/2 turn out it appears to be bending. If i break that bolt im screwed. Im just hoping that it does not leak since i already backed it out slightly.
I found an article where someone simply ran the wires up the transom above the water line drilled a hole and passed them though a stainless steel fitting and connected them like that.
Here is my problem. The trim position sensor (starboard side) has two wires as does the quicksilver replacement but the limit switch (port side) has 3 wires. The switch that comes in the kit has only two.
Anybody have any thoughts on this?
Thanks
Fun Times
It appears you may have bought an incorrect trim sensor kit...Your transom assembly serial number 1A446515 shows yours to be a Smart Craft model and yours having a 3 wire system suggests yours may be using both a digital and analog readout... Check out ordering Merc part number 8M0107462 online and image search to what you have.
EzPartsWeb and 1 more page - Personal - Microsoft​ Edge 6_26_2022 2_18_16 PM.png
Fun Times
What tool setup are you using to remove it all? Have a few photos of the tool and general bolt area.
It is recommended to pull everything apart to do the job...
Yegboats
yep! SMARTCRAFT TRANSOM W/ENGINE
ENG: 1A351574 40820011U MERCRUISER 8.2L BRAVO MPI
DRV: 1A502084 5447600TT MERCRUISER BRV 3X 2.00:1
TRN: 1A446515 6315001TS MERCRUISER BRAVO SMARTCRAFT
