Hello everyone, been trolling for some time, and finally have a question I can not seem to find an answer to.
I have a 2000 Cobalt 23LS with the Volvo Penta 7.4gi and SXM duoprop outdrive. I made the mistake of not winterizing, because I live in cenrtal Teas and have never had a freezing issue. Well cracked the block and manifold this past winter. The trim gauge has never worked, but while removing the trim sender i noticed the gauge move.
I asked the repair facility to check the issue while replacing the engine. He checked it and said the gauge and sender are fine. The problem is in a small black box "controller/ interface" mounted on the inside of the transome above the engine. He said these boxes go out pretty frequently. I have not removed it yet, I just got the boat back, to see what the part number is yet. I am very knowledgeable in both electrical and mechanical things, so he suggested I save some cash and swap it out myself since I do just anout everything else on the boat myself.
Does any one know what this "box" is technically called? I have tried to research it as "Trim controller, tilt controller, etc." but get unrelated links. Any help is appreciated, so I know exactly what it is called.
I am not so sure it is a controller per se, but more of an interface between the sender and gauge. There are 4 wires that are connected to it via ring terminal screwed on to the lower edge of the unit. I do know that with the master battery disconnect turned off a small red LED still blinks every 30 seconds or so. The only thing that works with the disconnect off is the engine tilt. I do not have trim tabs on the boat.
Thanks in advance, and special thanks to iboats for some of the parts I purchased for the engine swap.
