karbine98
Thread starter- Joined
- Mar 17, 2014
- 29
Got the outdrive for my '78 Sea Star Spoiler back in. Went to pull trim rams back in to reconnect them but one hung up on lower unit (no helper--couldn't see this). I heard a pop sound from bottom of trim pump/reservoir. Fluid appeared to be leaking from the hydraulic line in bottom of reservoir. Can I just re-tighten the connection? Do I have to have flare nut wrench? Doesn't look like it would be too hard to remove pump/reservoir. Disconnect battery, remove solenoid bolts, disconnect hydraulic line, and then the two bolts mounting the assembly. Don't want to but if needed I can. Any advice appreciated as always. Greg
