trim question
bensett004
first off this is my first time on the board so hello to all....i have a 1990 four winns 170 freedom, on saturday i was on the lake and my trim gauge started to flutter real bad....now it doesnt work at all, trim works but no gauge, just wondering if anyone had a suggestion on where the problem could be???any help is appreciated thanks
rndn
Re: trim question
First off, Welcome to the iboats.com forum!:):)
If your boat has a mercruiser with an Alpha 1 outdrive, it may be the trim sensor. It is located on the outdrive. It is a round piece with 2 srews attaching it to the outdrive. It may be dirty, water logged, or have a loose connection.
bensett004
Re: trim question
where do i look to see what outdrive it has?i know its a cobra....and where is the sensor located?
trap9
Re: trim question
How do you change the trim switch on a quicksilver 2000 . Do you take the shifther off to get to the switch?
