Riegfrghtl
Thread starter- Joined
- Jul 7, 2008
- 77
I have a 1972 mercruiser 888 with a prestolite trim pump. Trim has worked fine up until this past weekend. Trim pump will run in the up or down postion but sterndrive will not raise or lower. Boat is in the water at my slip in the marina so I haven't pulled it out yet to check trim cylinders or hoses. There is no trim fluid leaking into the bilge or in the water surrounding the boat. Is it possible for u-joint to seize up causing the sterndrive to stay in one position. If not, can anyone point me in the right direction to get started in fixing this problem? Thanks in advance for any and all suggestions!
Tim
Tim
