What do you think the problem is and is it fixable? https://www.youtube.com/watch?v=gey1O0fpEQA
natemoore Master Chief Petty Officer Joined Jun 13, 2009 Messages 844 Jun 18, 2013 #1 What do you think the problem is and is it fixable? https://www.youtube.com/watch?v=gey1O0fpEQA
Grub54891 Admiral Joined Jun 17, 2012 Messages 6,477 Jun 18, 2013 #2 Re: Trim pump noise. Listen then comment please. Sounds like the motor is going south. You should be able to get the motor and not the whole pump. However I've seen em run servral years sounding like that. Is it full of oil? Grub
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,525 Jun 18, 2013 #3 Re: Trim pump noise. Listen then comment please. It`s a dry bearing in the end cal or at the end that goes into the pump body. grub does have a point, they can run for years like that.
04fxdwgi Senior Chief Petty Officer Joined Jun 10, 2011 Messages 754 Jun 19, 2013 #4 Re: Trim pump noise. Listen then comment please. Odd. Sounds just fine going up, but like crap going down.
