Trim Problems
4whatitsworth
I Have a1999 50 h p. The Tilt and trim works good going down but can't get it to go up. I Have worked it and bled it for 2 days. Can't get the air out. Someone has stripped the manual screw on it. Any suggestion?
boobie
Get the manual screw fixed first, then get it in the full tilt position and check your fluid level.
Roberthill
Check your up limit switch , it has a plastic plunger and sometimes it sticks causing a break in your circuit.
