Trim Problems
TunTavern
I bought my first used bass boat a couple months ago. There have been no major issues with this boat until now. While the boat was trailered in my driveway, the motor trimmed all the way up. I'm not sure how long this lasted...could've been a few hours while I was at work. It appears the trim button on the motor may have been stuck. This is weird because it's been over a week since I last had the boat in the water. My problem...I can still trim up and down but it makes some nasty grinding sounds like something's binding. The trim motor also sounds and looks weak when engaged. Could the trim motor be fried or will I have to replace the whole hydraulic lift system?
Jacket4life
Re: Trim Problems
Check your fluid levels first, then I'd replace the trim switch. If they are left in the weather, they fail fairly regularly.
TunTavern
Re: Trim Problems
Thanks...haven't checked the fluid levels yet. Worked on it yesterday and seems the trim relay is bad.
TunTavern
Re: Trim Problems
Trim malfunction was caused by a faulty trim switch on the engine cowl. I disconnected that switch, and will order a new one from mercury. The other 3 trim switches on my boat still function properly. While inspecting the trim relay assemblies mounted on the engine, I also found a burnt out voltage regulator. Replaced it and some of the wires which were cooked. Charging system and tachometer are all working now.
