Trim problem 1997 Force 120 hp outboard
wbzad
The power trim will lower the engine, but when the up switch is activated all we get is a click from the relay. We have tested the relays and all of the wiring on the trim on the engine from the relays down to the motor. Have switched relays everything. Cannot get trim motor to run and lift the engine up. From other posts I am thinking it is still the relays, but now I cannot find a relay except from a dealer for lots of dollars. I am looking to buy the relays to eliminate them from the equation I have gotten two different numbers for the relay one from Merc direct and one from a Merc dealer, but I don't see either of these numbers cross referencedon this part site or any other. The numbers from Merc direct is 88275A1, and from the dealer it is 818997T1. anyone got any idea on where I could get my hands on 2 of these realys and not cost me an arm and a leg. I am anxious to get out Walleye fishing the run has started in Depere Wi.
Thanks
Frank Acampora
Re: Trim problem 1997 Force 120 hp outboard
If they are the 5 pin relays, then they are a standard part. Go to any industrial electrical supply store. You may need to settle for relays without the mounting tabs but they all work the same. Price: someplace around 20 bucks each. See my private message to you.
