Re: Trim not working
I had no power at any wire except red.Another test is to check the voltage at the small blue wire on the solenoid as someone holds the trim up switch on. Then check it as they hold the trailer switch on. Then go to the small green wire on the other solenoid and check voltage as someone holds the trim down switch on. Should have 12 volts as they hit the switches.If you have voltage than the solenoid is bad unless the large wire connections are dirty and not making contact. Disassembling the motor is the last place you would go.
