ryanmcorder
- May 29, 2007
- 3
Thanks for the response. I have searched through many of the Trim motor posts but can not find one that is quite like the problem I have since the trim motor actually broke off from where it was mounted while the boat was in the water. So I am concerned that salt water most likely has mixed with the hydraulic fluid and its possible effect on the mechanical parts on the inside of the lift system. Any advice on my circumstance or what I need to do while installing the new trim motor would be greatly appreciated. The motor is a 1984 115 hp Evinrude 4 stroke. Thanks.
