Trim motor quit working...
SS194
Last summer my trim motor worked great. My boat sat all winter in my garage and now it doesn't work at all. I think when I try to bring the outdrive up, I hear it click, but that's it. And it makes no noise at all when I try to go down.
It's funny how things seem to break when they sit.
Now last year when the motor did work, I did have a problem with the outdrive leaking down. There were no external leaks, so I assumed that it was the seals in the actuators. I could be wrong.
Where do I start? There is a shop that'll rebuild the motor for right around $100. I'll check electrical connections first.
Is it possible to have someone rebuild the pump? Or should I just get a new one.
Thanks,
Steve
Re: Trim motor quit working...
Ayuh,.........
That's a Good Place to Start........
Bring your Test Light with you,+ See where the Power Stops.........
SS194
Assuming all of the connections are good (which it looks like they might be), I can get a used one with a 30 day warranty for $175. Sound like a good thing to do?
All I know is these trim motors are expensive new. Any idea how much to have one rebuilt?
Thanks,
Steve
Well,........
Those questions are Pretty Tough to Answer.......
You Still haven't said Anything about What we're working on..........
Other than it's got a Trim Pump.......
SS194
Ah sorry, it's a 1976 Slickcraft 17' ski boat w/ a Ford 302.
SS194
I took it to a starter and alternator place. Turns out the motor is dead.
