Whistletrout
Thread starter- Joined
- Jul 24, 2019
- 2
I have a 93 Johnson 90 hp V4 that usually runs amazing. Starts up every time, gets yearly tuneups and has never let me down. The last few times out on the water however it has started bucking slightly and losing power, sometimes even shutting off. It always starts right back up and most times the problem will go away after a few minutes of idling. The only pattern that seems to be consistent is that I'm trimming the bow up for waves. Running the boat (93 four winns freedom 180) with muffs in my driveway it will run all day, until I trim it up....then I need to squeeze the bulb to keep it running. No gas leaks and I know that gas is getting through the lines. Gas filter in engine also looks clear and clean. Any ideas?
