Trim issues twin 250hp EFI 1999
WrestleSmart
Stb trim works at transom, Port does not. Neither work at helm. Both fuses checked good, both relays checked good.
thanks in advance.
aussieflash
Re: Trim issues twin 250hp EFI 1999
clean wiring on solenoid/relays.Including ground and tighten up.Could be switch going bad...starts to play up intermittently.
WrestleSmart
Thanks, It was a combination of things bad fuse holder on engine and corroded connections on switch all is good now.
Thanks again.
