So trim was acting intermittent and slow, then started to only work while motor running. Eventually it stopped working all together. When I got it at home I noticed that the blue green wire harness had deteriorated to where there was no insulation on the wiring staring at the trim motor up about 18”. So the where touching each other. When I separate the wires all I get is a click from either relay. Motor still starts. Could shorting the blue and green wires burn out the motor or the solenoid?
